1/32 Tamiya Corsair with BRASSIN P&W R-2800 engine
pg265
Senior Member
Post by pg265 »
Hi,
I recently started to work on the Pratt and Whitney R-2800 resin kit from Brassin, to add details to the 1/32 Tam Corsair.
Parts cut from the resin sprue.
Some parts:
Original spark plugs are not bad, but... details can be added.
New connector.
Cylinders head drilled to receive a "real" tube instead of the PE one of the Barssin kit.
Pascal 8-)
pg265
Senior Member
Re: 1/32 Tamiya Corsair with BRASSIN P&W R-2800 engine
Post by pg265 »
Me again...
The box of the lower cylinder is also drilled to be connected to the reductor and the back of the engine.
Test fit:
Early Bendix electrical harness from Barracuda
Next step: Paint.
So time to mask...
Late Distributors are cut off and will be replaced by the Early ones provided by Barracuda:
More mask:
Pascal 8-)
pg265
Senior Member
Post by pg265 »
Again and again...
ZP primer and black before Alclad, from ZP once again:
Short dry time, then grey from Gunze: 307 & 337 with Tamiya thinner.
Alclad White Alu for the cylinders.
Pascal 8-)
pg265
Senior Member
Post by pg265 »
Guess who.... :mrgreen:
Black again.
Welcome to the Smurfs:
Mask off:
Pascal 8-)
pg265
Senior Member
Post by pg265 »
...I'm still there :!:
Black here too:
Pchiiit...
Mask off and light first weathering steps.
test fit:
Pascal 8-)
pg265
Senior Member
Post by pg265 »
:oops: ...
Instruction plate added
First row:
Test fit again with front end:
Bendix distributors:
Time for primer!
Grey Micro Filler on few parts.
Cylinders:
I love the details:
Pascal 8-)
pg265
Senior Member
Post by pg265 »
:lol: ....
Other engine parts and cowls:
After the grey... BLACK!
Gloss Black Base from Alclad.
"Engine Manifold" from Alclad.
Pascal 8-)
And then you call yourself a newbie in your introduction! That is some master modelling, great stuff.
a stunning body of work on a small piece of engine, even in 1/32. Wow....not a newb in my book.
great work
