Debonder...
Debonder...
I bought a bottle of debonder at Hobby Lobby over the weekend. I know it’s used for debonding CA glue, but will it work with ordinary hobby glue? (tube and liquid glue) The ‘57 Nomad kit has rear wheel well/rear interior panel and rear deck glued on the chassis I want to remove and fix it for a better fit.
Re: Debonder...
Tom,
I would strongly recommend against using CA Debonder for anything except a CA join. CA joins are not melted or fused together the way liquids such as Tamiya’s or Mr Cement are. A CA join will pop apart whereas a fused join will not. If you used Tamiya cement, then you should use a razor saw—preferably the thinnest blade possible and a sharp X-Acto to cut the pieces apart.
Re: Debonder...
A panel line scriber (repeatedly drawn along the joint) could also be used, but it depends on the joint.
Re: Debonder...
Try putting the parts in the freezer for 30 minutes. Sometimes they will pop the join
Re: Debonder...
Or, a hammer. Hammers work.
A sharp fine scriber will work, too. By the way, debonder will take paint off in a hurry...I know.
Re: Debonder...
And we all know why Lyle knows this.
Re: Debonder...
Testing. Lots of testing.
Re: Debonder...
Oh Lyle.... only you would come up with that suggestion....LyleW wrote:Or, a hammer. Hammers work.![]()
Re: Debonder...
Inspired by young Lyle...
Re: Debonder...
I absolutely love Calvin & Hobbs....
