T-6 Texan II
Scruffy
T-6 Texan II
Post by Scruffy »
So, one of the things I wanted to accomplish over this weekend was to finish this thing up. I started it last summer, but had to order a set of decals and for no good reason, it took about six weeks to get them. Unfortunately, I was at the point where I needed them and there wasn't much I could without them, so after waiting a couple of weeks I moved on to other things and the mojo for this went away. I need it finished by June 6th so this is down to the wire.
This is the Ibex T-6 kit in 1/48, which is a decent kit, similar very much to a limited run kit, the panel lines in many areas are not as crisp as one would like, small parts okay, but the sprue attachments are rather large compared to the part. The decal sheet is really nice, and some of the important parts are provided in resin. The nose, seats and wheels being the most prominent resin pieces.
As usual I started with the cockpit, the instrument panels repersent the ones on the T-6A, so that kind of dictated the markings I used. The kit panels were detailed with a combination of the kit decals and ones from Air Scale. A large nut/bolt/washer casting was added to the center leg of the panels for the climate control vent.
The resin seats look good all painted up. I added the brace between the canopy breakers on the front seat, the crotch pull rings from streached sprue, and the leg restraints from Tamyia tape panted blue.
The canopy is vacuformed, and once trimmed up fits quite well. I chose to place it closed as the canopy is so large that it contributes alot to the shape / contour of the aircraft. Plus it is large enough that the cockpit is still qiute visible.
Before the canopy was added the last of the cockpit details were added, including the landing gear leavers to the instrument panels,and parking brake lock to the front panel only.
Color going on, Model Master Gloss Sea Blue.
Markings going on, from the Two Bob's sheet for the T-6A/B
The nose checkers were all individual strips, and singular checkers. The anti glare panel seemed to be the datum for these. The difficult thing was to get it masked symmetrically, and sized correctly. Unfortunately, some of the panel lines shown on the decal instructions are not on the model. Ultimately, it came down to best guess and luck to get the anti glare panel dimensioned and masked. It seems to correct though as in the end, all the checks seem to line up as they should.
This was as far as I got before my break from it. so first thing was to finish the decals.
The final gloss was applied, and the masking from the canopy was removed. There was some touch up required here as the masking had been on so long. Nothing too serious, but annoying non the less. So now the final construction starts...
Re: T-6 Texan II
Subscribed! I will follow along with you until the end! All the best!!!
Re: T-6 Texan II
Now that's class - what a very nice looking aircraft, that paint is excellent!
Re: T-6 Texan II
Very nice build and for me totally a new brand, Ibex !
Never heard before, but looking at the details, seems to be pretty good based on the pics
Re: T-6 Texan II
Very nice!! I've wanted this kit for a long time. I want to do a Randolph AFB one.
Scruffy
Re: T-6 Texan II
Post by Scruffy »
Thank you Gents, appreciate the comments.
Kari- It is a pretty decent kit, the only real down sides are that the panel lines are rather wide and soft as is common with alot of limited run type kits, especially on the under side of the wings, and the vacformed canopy. The canopy fits very well once trimmed and sanded to fit, and the frame lines are very distinct, which helps when doing the trimming. Some people don't like messing with them is all.
Medic- yeah, this is one I had wanted for a while as well, I found it in a hobby shop on the other side of the state. We were over in that area and I stopped it, and really wasn't looking for anything in particular, but there it was :lol: The kit is still avaliable from Isracast, Spruebros did have some, and the kit has been upgraded so you can build a "B" model as well, main differences are the instrument panels and the "B" has a HUD in the front cockpit.
Re: T-6 Texan II
Are those “Centenial of Naval Aviation” markings?
Scruffy
Re: T-6 Texan II
Post by Scruffy »
Yeah, those are CoNA markings. The Navy painted up two T-6's, this one and an all yellow T-6B. I was going to do the yellow one, but I really didn't want to scratch up the new instrument panels and the blue scheme started to grow on me so I just went with it.
She is up on her legs now.......
I made the base from a 98 cent WalMart picture frame, a piece cut from a large Costal Kits tarmac section I won for free, and cut a piece of scrap plastic to shape for the name plate. The letters on the name plate came from the header of the decals sheet.
Re: T-6 Texan II
Wall Mart picture frame... :hmm:
I like it! Even less work than those Hobby Lobby plaques that I pick up...
Re: T-6 Texan II
Those are some wonderful improvisations!!! Especially the part of the decals everyone tosses out! Very cool!!!
:shoutout:
