1:48 Prowler and Intruder
first my Revell EA-6A build OOB
Re: 1:48 Prowler and Intruder
Nice
:that:
I do really like the EA-6A. Sort of a cross between the A-6B and EA-6B, and very much a little known member of the Intruder family.
I love it! I've done a couple in my youth years. Fun builds. Not sure if I still have my build tucked away though.
The last time I decided to check my build stash since I moved here in September 1998, quite a few were beyond repair and lost from too much jostling of boxes. I actually ended up tossing about 90% of those kits. Talk about a huge heartbreak of losing a part of my sweat and hard work building all those kits.
and the A-6E; VA-52 Knightriders, USS Kitty Hawk
Well done!! The carriage under the Prowler, did it come with the kit or was it something you found in a US Navy ground support equipment kit?
Very fine work indeed! But what is that under the rear end ahead of the tail hook? Some sort of open access panel?
That’s what that is? Never got a good look at it. It looked like some carriage of sorts on wheels. :headslap:
Stikpusher wrote:Very fine work indeed! But what is that under the rear end ahead of the tail hook? Some sort of open access panel?
this is the Elo-Avionic Box from Eduard, all PE and wire and the antenna from the kit
Congratulations, Cherrylock!
