1/48 Hasegawa Macci c.202 Folgore
Modelcrazy
Post by Modelcrazy »
I thought I would post my progress on the site and catch anybody interested up on my progress since I’m new to SPAM.
I’m building the 1/48 Hasegawa Macchi c.202 Folgore with the Eduard flap PE set and the CMK Italian pilot/mechanic figures. I absolutely love Italian aircraft with the Falco being number 1.
To forewarn you, I’m not great on figures but with some pointers from another site I hope to get better. I could always use some pointers from anybody.
I started with the usual pit, fuse hales, wing/tail attachment and seam filling. I added some of my own detail into the pit, drilling the holes into the seat and constructing tape belts with some extra PE for the buckles. The upper cowl did give me a little problem. If I had just popped it in, the center would have sunken lower than the rest of the cowl. I had to glue the front and center then glue the rear once dry. I started installing the flap PE set prior to the wing attachment to make it easier to construct the ribs. I continued to install the rest of the parts once the wings were assembled.
Now to catch up, I was able to get some work done yesterday and painted the green base coat. I will apply dots of Silly Putty and go over this with the sand color to get the effect I want. I’m going with the box camo scheme of 150 Gruppo.
After talking with Stickpusher and doing some research I decided to not go with Hase’s color call out and instead go with the Stormo color guide,
http://www.stormomagazine.com/RegiaAero ... WII_3a.htm Index D2
This is what I found.
Grigio Azzumo Chiaro 1 (Light Blue Grey 1) or FS 36307 Light Sea Grey for the gray underwing and inside the flaps and wheel wells.
Nocciola Chiaro 4 (Light Hazel 4) or FS 30219 Dark Tan
Verde Oliva Scuro 2 (Dark Olive Green 2) or 34052 for the green
I noticed I had something wrong with the port gear door. It sits way too low and almost scrapes the ground. I need to look into this and correct it.
I worked some on the guys and repainted the flight suit green rather than tan. After looking up some colorized picture the flight suits were green. The vest and parachute will still be tan. I'm having a hard time with the mechanics face. I can't seem to get it to look right. The pilot is looking good to me though...maybe a little sunburnt but.....well they are in the desert after all.
That's all I have for now. I'll get some more time on it soon.
Steve
Re: 1/48 Hasegawa Macci c.202 Folgore
Those dropped flaps look good. Was that a lot of work?
I am asking because I have a few PE flap set in my stash but I always think that it is a lot work.
Modelcrazy
Borg
They were surprisingly easy. I was a little apprehensive about starting them but was pleased with how well they went together.
Steller work thus far!
Welcome to the Forum!
Lookin' good Steve! Wow man!!! I love these planes and don't even have one in the stash!
Modelcrazy
Thanks Portman & Mustang,
I found out what was wrong with the gear door. After inspection I saw there wasn't any way of misalignment due to the alignment pins, but I noticed that the port gear had dried pointing to far forward. After some "realignment" all looks as it should.
Modelcrazy
Worked some on my guys last night. Still not happy with the mechanic but fairly happy with the pilot. Does anybody have any product suggestions to cut the semi-gloss appearance? I tried Dull Cote but that is what made them glossy.
I still have s few things to do to them yet.
Modelcrazy
I applied the Silly Putty to the 202 for the camo. It made it look like it had the measles. Next will be the underwing grey.
Steve
That looks very sharp!
Modelcrazy
Thanks Stick.
