Shark mouth Mi-17 - Hobby boss 1/72
BsYamato
Post by BsYamato »
Started this kit some night agoand withouth take sprues pictures (i'll post later, another copy in the stash :lashed: ).
Really like the mi-8 family and this kit is well engineed to simplify the building but some mod has done :hmm:
Markings wil be in Czec shark mouth of boxart
What you can see from opened rear
Cut rear doors to display them opened , out of the signed cut in the kit , another cut on each door is needed and remove the joint pins. Also the two pieces cockpit bulkead glued in the first picture and glued wheels and exhausts (removed inner pins )
To fit the opened door triangle, the rear seats need some trim
Heres some more detail added
Doors and bulkead ready for paint
Windsreen houses seems too large for me, so i removed them , also glued side fuel tanks and filled all holes in the inner fuselage
To improve paint grip i sanded or scratch with 11# blade all frames
Instead of the Kp or Zvezda kit, the hobby boss have correct front windows arc, not parallel as the other two moulds
A dry fit test, also rotor blades are just fitted, not glued
Painting inners:
Doors almost ready
Theres no instruments printed in upper consolle, so i painted them :bag:
Almost done
At least a fire extinguisher is needed :hmm:
As you can see a white drybrush was done on the pieces and also a light layer of gloggy clear to protect for next step : washing.. Till now only acrilics was used , so i'll wash with humbrol enamels .
At the next! :guitar:
Re: Shark mouth Mi-17 - Hobby boss 1/72
I never thought much of the Hip one way or another until I saw them in person on a daily basis in Bosnia. Then I became quite impressed by the machine. Big and powerful like a P-47 or Sea Fury. I will definitely follow this project!
Hip! (That is Dutch for cool)
BsYamato
Post by BsYamato »
BorgR3mc0 wrote:Hip! (That is Dutch for cool)
:lol:
Really intresting machine Stick, theres lots of possible scheme, the other hip under wip, the KP, i'll try to finish finnish :quotes: . The other hobby boss , surely russian but can't exclude more kits in future :hmm:
Updates about this one:
Washing inners and semigloss clear layer to seal
Seats ready
Added cockpit door window not included in the kit, made from acetate sheet
filling cockpit
Glued windows with some sanding work and tamiya green cap, painted in black borders and refined with interior grey
Now i forget to paint exhausts , so i can't close fuselage for now :whistle:
Also i lost the top door upper cockpit :scream:
At the next!
BsYamato
Post by BsYamato »
More about the hip
Exhausts, primer, black, silver and brown drybrush
In place
Last picture before to close
And mummy is ready.
Not perfect fit after painted inners :(
At the next
That's a good looking build BSY - Great subject too.
Wouh, beautiful, those exhaust "pipes" look fantastic!
BsYamato
Post by BsYamato »
glued the front glazing some week ago and some putty'n'sanding. Today more sanding session and heres some update picture :)
At the next
Coming together very nicely there! :dogwag: Now that the fuselage is together it is really taking on final shape.
BsYamato
Post by BsYamato »
Forget to update the mil!!
Masked the windows with superscale liquids and masking tape . A base of humbrol 89 lighten with white was put on the whole helo as primer and more layers in the bottom where needed
rotor on.. Must say that the KP have better weighted blades!
more masking for the lighter camo color, humbrol 94
two layers
And after three layers
At the next!
